Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The lens can be safely removed in only seven simple steps.
Выберете то, что вам нужно
Remove the following eleven screws securing the covers to the ZS3
Eleven 3 mm Phillips screws
Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
Using a spudger, flip up the locking flaps on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
Disconnect the LCD ribbons gently using the spudger.
Using your fingers or a spudger, gently remove the lens mechanism from the rest of the camera.
Unlock lens mechanism located on the bottom of the device using your fingers.
