Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the following eleven screws securing the covers to the ZS3
Eleven 3 mm Phillips screws
Use the flat end of a spudger to pry apart the back cover from the rest of the unit as shown.
Using your fingernail or a spudger, flip up the ZIF locking flap on the two LCD ribbon cable sockets that connect the back cover to the rest of the unit.
Remove the two LCD board ribbon cables out of their sockets.
Remove the three 3 mm black screws that surround the lens using a Phillips #00 screwdriver.
Flip up the locking flaps on the two LCD ribbon cable sockets with the spudger.
Use the spudger to disconnect the LCD ribbons.
Use your fingers or a spudger to gently remove the lens mechanism from the rest of the camera.
Unlock lens mechanism located on the bottom of the device using your fingers.
