Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
The X9 requires removing the exhaust for oil changes, rear brake pad or rotor replacement, and rear tire replacement.
Выберете то, что вам нужно
Loosen the exhaust strap:
Use an 12mm wrench to loosen the exhaust band lock nut.
A 6mm Allen key is required to unscrew the bolt at the bottom of the band.
Once the bottom of the strap is loose, you can push it upward and slide the retaining pin that secures the top of the strap out to release it.
A Torx T40 driver is required to remove the final bolt securing the exhaust.
The Exhaust assembly is now free. Pull and wiggle the muffler back (taking care not to damage your exhaust joint gasket) until the muffler comes free from the header pipe.
2 участников успешно повторили данное руководство.
