Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Place your thumb on the battery cover and push left towards the arrow.
Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
Under the screen, locate the black plastic strip that sits above the white plastic strip.
Pull both sides of the black piece upward-about a mm.
Once the piece is lifted carefully slide the screen out of the slot.
Remove the four 6mm screws from the inner casing using a Phillips #00 screwdriver.
Pull the inner casing off. If all the screws are out, the casing will come off easily.
Use the pointed end of a spudger to push the push-pin partly through.
From the other side pull the pin all the way out. The battery cover will fall off.
The spring can now be pulled out of its resting position/holes.
