Введение
How to replace the LCD screen if it is broken or cracked.
Выберете то, что вам нужно
Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
Under the screen, locate the black plastic strip that sits above the white plastic strip.
Pull both sides of the black piece upward-about a mm.
Once the piece is lifted carefully slide the screen out of the slot.
