Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Запчасти
Детали не указаны.
  1. Locate the battery cover on the bottom of the camera.
    • Locate the battery cover on the bottom of the camera.
  2. Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
    • Place your thumb on the battery cover and push towards the arrow. The cover will release and pop open.
  3. Remove the batteries from the camera.
    • Remove the batteries from the camera.
  4. Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
    • Unscrew and remove four (3mm) screws on the right side of the camera. This will release the front and back casings.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  7. Locate the black plastic strip under the screen above the white plastic strip.
    • Locate the black plastic strip under the screen above the white plastic strip.
  8. Pull up both sides of the black piece up about a mm.
    • Pull up both sides of the black piece up about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
  9. Unscrew and remove the four (6 mm) screws on the inside casing.
    • Unscrew and remove the four (6 mm) screws on the inside casing.
  10. Pull the inner casing off of the camera.
    • Pull the inner casing off of the camera.
  11. Unscrew and remove the four (4mm) screws from the logic board.
    • Unscrew and remove the four (4mm) screws from the logic board.
  12. Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
    • Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
Заключение
Dani
Участник с: 24.06.2010
21 Репутация
Автор 7 руководств
Команда
Cal Poly, Team 3-3, Johann Summer 2010 Участник Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 членов
Автор 7 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 815
