Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Place your thumb on the battery cover and push left towards the arrow.
Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
Under the screen, locate the black plastic strip that sits above the white plastic strip.
Pull both sides of the black piece upward-about a mm.
Once the piece is lifted carefully slide the screen out of the slot.
Unscrew and remove the four (6 mm) screws on the inside casing.
Unscrew and remove the four (4mm) screws from the logic board.
Use a spudger to pry up all four sides of the logic board and slide it out of the camera.
