Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Запчасти
Детали не указаны.
  1. Disconnect the power supply cord from the outlet.
    • Disconnect the power supply cord from the outlet.
  2. Remove the eight screws holding the wood-patterned cover to the microwave frame. The first four screws are located on either side of the microwave front.
    • Remove the eight screws holding the wood-patterned cover to the microwave frame.
    • The first four screws are located on either side of the microwave front.
  3. SKIP THE UPGRADE
    Save by fixing with an all-in-one kit.
    Shop iPhone Fix Kits
    SKIP THE UPGRADE
  4. Remove the additional four screws securing the wood-paneled case to the microwave frame. Remove the additional four screws securing the wood-paneled case to the microwave frame.
    • Remove the additional four screws securing the wood-paneled case to the microwave frame.
  5. Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame. Lift the case upward slowly until the case is free of the microwave. Lift the case upward slowly until the case is free of the microwave.
    • Placing your hands on either side of the case, slide the case back gently until you feel it completely separate from the microwave frame.
    • Lift the case upward slowly until the case is free of the microwave.
Заключение
3 участников успешно повторили данное руководство.
Samuel
Участник с: 26.09.2012
142 Репутация
Автор 2 руководств
Команда
Cal Poly, Team 2-12, Propen Fall 2012 Участник Cal Poly, Team 2-12, Propen Fall 2012
CPSU-PROPEN-F12S2G12
3 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 6
За всё время: 1,710
