Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Выберете то, что вам нужно
Use a flat tweezer and take off gently Flexible volume button from the left side.
Do the same for the right side.
Lift the sensor/earpiece cable with the opening tool.
Don't force, you may damage the soldering.
Lift the logic board from the right side.
Use the removal tool to unplug the display cable from the logic board.
You can now separate the Logic board from the display assembly.
Use the removal tool or a spudger to unplug speaker module cable
And separate the speaker module from Logic board.
34 участников успешно повторили данное руководство.
2 Комментариев
Thanks for the post. This is really Helpful
im curently selling one thx to you
