Введение
This guide will allow users of the Samsung Galaxy S Blaze to understand how to take the phone apart. The guide will make future repairs easier to accomplish. The disassembly of the phone is an easy process with no surprises. You will need to be careful with the screws that are inside the device, the screws will strip easily. To properly disassemble the phone you will need a Phillips Head screw driver size 00 and a flat wedge opening device.
Выберете то, что вам нужно
Remove the frame from the phone by using the blue plastic opening tool.
Work around the phone with the tool until the frame is off.
The SD card slot is held in place by a small tab.
Unhook the tab of the SD card slot from the frame of the phone.
The power button is attached to the phone with two prongs.
Unhook the prongs of the power button from the frame of the phone.
Use the blue plastic opening tool to unlatch the wire ribbons from the motherboard.
Unlatch the final ribbon cable connector from the phone.
Remove the motherboard from the phone.
If there is something wrong with your device, try this: Samsung Galaxy S Blaze 4G Troubleshooting
2 участников успешно повторили данное руководство.
