Выберете то, что вам нужно
With the door open, use a flathead screwdriver to remove the "Cap Top Table"
Remove the 3 screws from the top that hold down the "Top Table"
Remove the Top Table
Disconnect the electrical connector located above the upper left door hinge.
To disconnect the connector, press the raised end of the white part while pulling out.
Disconnect the water tube by pulling the tube fitting out away from the white plastic connector.
Using a Philips Head Screwdriver, remove the grounding screws.
Use a 10mm Socket Wrench to remove the 3 hex bolts.
Disconnect the LED Housing using a Philips Head Screwdriver
Remove the ground screws using a Philips Head Screwdriver
Remove the 3 HEX bolts using a 10mm socket wrench.
Remove the lower left and right door hinges using a Philips Head Screwdriver. Use a 10mm wrench to remove the 2 flathead screws.
To remove the door, lift it straight up.
