Выберете то, что вам нужно
Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
Using the philips screwdriver, remove the two screws on the mother board.
Place the pry tool in-between the front cover and mother board.
Gently separate the front cover.
After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
Еще один человек закончил это руководство.
