Выберете то, что вам нужно
Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
Once the back cover has been removed the battery will be visible.
Pry the battery from the device.
Once the battery has been removed you can see the motherboard.
Unscrew 4 screws on the metal docket using a Phillips head screw driver.
The USB connector can now be taken off of the device.
