Disassembling Sanyo VPC-T850 Outer Casing
Выберете то, что вам нужно
  1. Disassembling Sanyo VPC-T850 Outer Casing, Disassembling Sanyo VPC-T850 Outer Casing: шаг 1, изображение 1 из 1
    • Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
    • Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
    • In the compartment, move the small notch and push down on the battery to remove it.
    • During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
  2. Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: шаг 2, изображение 1 из 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: шаг 2, изображение 2 из 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Screws: шаг 2, изображение 3 из 3
    • Remove the eight screws around the sides and bottom of the camera using a Phillips #00 screwdriver.
  3. Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: шаг 3, изображение 1 из 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: шаг 3, изображение 2 из 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Rear Panel: шаг 3, изображение 3 из 3
    • Using the spudger, gently pry the rear panel away from the left side.
    • Be careful not to damage the three green cables as you remove the rear panel of the camera.
  4. Disassembling Sanyo VPC-T850 Outer Casing: шаг 4, изображение 1 из 1
    • Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
    • Do not put any excessive force on the green wires.
  5. Disassembling Sanyo VPC-T850 Outer Casing: шаг 5, изображение 1 из 1
    • Separate the rear panel from the rest of the camera.
  6. Disassembling Sanyo VPC-T850 Outer Casing: шаг 6, изображение 1 из 2 Disassembling Sanyo VPC-T850 Outer Casing: шаг 6, изображение 2 из 2
    • Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
    • Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
  7. Disassembling Sanyo VPC-T850 Outer Casing: шаг 7, изображение 1 из 2 Disassembling Sanyo VPC-T850 Outer Casing: шаг 7, изображение 2 из 2
    • Carefully pull off the side covers wrapped around the camera.
  8. Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: шаг 8, изображение 1 из 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: шаг 8, изображение 2 из 3 Disassembling Sanyo VPC-T850 Outer Casing, Remove Front Cover: шаг 8, изображение 3 из 3
    • Using the spudger, gently lift off the front cover of the camera.
    • The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
Заключение
Jonathan Yau
Участник с: 04/11/10
26 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 27-95, Amido Spring 2010 Участник Cal Poly, Team 27-95, Amido Spring 2010
CPSU-AMIDO-S10S27G95
4 членов
Автор 4 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 2
За всё время: 2,038
