Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This is how you would remove the outer panels of the Sanyo VPC-T850. This step is required for any repairs or a tear down.
Выберете то, что вам нужно
Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
Slide out and open the hatch located on the bottom-right side of the camera.
In the revealed compartment, move the small notch and push in on the battery to remove it.
Using the Phillips #00 Screwdriver, remove the 8 screws located around the sides and bottom of the camera.
Using the spudger, slowly pry the rear panel away from the left side.
Using the Phillips #00 Screwdriver, remove the 8 black screws connecting the green keypad chip to the rear panel.
Using the Phillips #00 Screwdriver, remove the 3 screws located across the top of the camera.
Using the spudger, gently pry the front cover of the camera off.
