Введение
This guide will show you how to open the radio casing to diagnose internal issues and check internal connections.
Выберете то, что вам нужно
Press down on the two tabs at the top of the door.
Rotate the door away from the radio, towards you.
Lift the door out of the three smaller tabs on the bottom.
Push the batteries against the spring and pull out using your finger to remove them.
Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
Grasp the radio from the front and back halves and gently pull apart to separate them.
Pull the white plug out from the red outlet in the Orange circuit board in the back face of the casing.
4 участников успешно повторили данное руководство.
