Введение
Removing the front cover is a necessary first step in disassembling the camera in order to repair or replace any internal parts.
Запчасти
Никакие детали не требуются.
  1. Locate the battery door at the bottom of the camera. Press down on the door and  slide it back.  The door will pop open.
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Remove the battery from the door that you opened in the previous step.
    • Remove the battery from the door that you opened in the previous step.
  3. Free shipping on all orders over 100,00 $ or containing a Pro Tech Toolkit!
    Посмотрите наш магазин
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  4. There are two screws on the left and right sides of the camera, and two screws on the bottom. Use a PH00 screwdriver and remove the six 2.9mm screws. Use a PH00 screwdriver and remove the six 2.9mm screws.
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  5. Use hands to gently pry the front casing away from the camera. Use hands to gently pry the front casing away from the camera.
    • Use hands to gently pry the front casing away from the camera.
Заключение
iDeleted
Участник с: 07.07.2010
2 101 Репутация
Автор 39 руководств
Комментариев: 0
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 2,266
