Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide acts as a prerequisite for the guides following it. This will show you how to disassemble to phone enclosure in order to access the internal components of the device.
Выберете то, что вам нужно
Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
Remove the rubber plug located near the camera by gently prying upward with your fingers.
Gently lift the camera shield after removal of the rubber plug.
Pry the remaining panel to loosen its contact to the phone using a spudger.
Slide the panel upward to remove it completely.
Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
Gently pull the ribbon from the circuit.
Remove the now disconnected screen.
2 участников успешно повторили данное руководство.
