Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the plastic cover from the back. Pry it off from the top first with a thin plastic shim, then remove it from the two bottom clips.
After removing the screws, the two halves will separate. If not, then pry them gently apart.
Remove the circuit board and screen from the device.
Use your T6 to remove the 4 screws holding the cover on.
Lever out the microphone using a small screwdriver or any similar tool.
Carefully remove the plastic clips holding the screen on the board.
Remove the speaker located in the screen housing just above the screen.
Gently pry it out with a small screwdriver or similar tool.
Remove the plate from the circuit board protecting the more delicate processing parts.
Congratulations, you have successfully disassembled your Sony Ericsson T68i!
6 участников успешно повторили данное руководство.
