Запчасти
Детали не указаны.
  1. Flip the toy over, so that the keypad is facing away from you. Remove two Phillips-head screws.
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
Заключение
bushing
Участник с: 23.04.2010
9 093 Репутация
Автор 13 руководств
Один комментарий
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 2
За последние 30 дней: 22
За всё время: 4,241
