Disassembling Thinkpad Yoga 460 Back Cover, (old name: s3)
Выберете то, что вам нужно
  1. Disassembling Thinkpad Yoga 460  Back Cover, (old name: s3), Preparation: шаг 1, изображение 1 из 1
    • Make sure you have disabled the battery in BIOS/UEFI
  2. Disassembling Thinkpad Yoga 460  Back Cover, (old name: s3), ESD: шаг 2, изображение 1 из 1
    • Make sure your workplace is ESD secured
    • An ESD workmat and a ESD wristlet will get you far
    • Don't continue if your knowledge on ESD is lacking !
    • TEXAS instruments ESD guide
  3. Disassembling Thinkpad Yoga 460  Back Cover, (old name: s3), Remove Cover: шаг 3, изображение 1 из 1
    • Purple screws dedicated to the keyboard, none of them should need removal
    • The bottom three screws has a rubber head upon them. Make sure you remove them carefully(some kind of adhesive on them).
    • Note that the screws will not jump out easily even though they are loose,
    • Spry very carefully when all screws are removed. Be extra carfeul close to the headphone jack. HAVE PATIENCIE
  4. Disassembling Thinkpad Yoga 460  Back Cover, (old name: s3), The Inside: шаг 4, изображение 1 из 1
    • Remove the purple cable(battery). Might not be nessesary if you followed step 1 correctly
    • ESD protect yourself and your tools
    • The blue indicates the M.2. SSD 42mm (2242). 256GB worked perfectly for me. Only exists if you have a version with separate cache.
    • Green box indicates the HDD
    • Red: RAM slot SO-DIMM DDR3 (only one) 8GB
Заключение
7 участников успешно повторили данное руководство.
Endorph
Участник с: 10/07/14
2 097 Репутация
Автор 8 руководств
2 Комментариев
Since older Lenovo are identical to open just look for an older model in case you have a brand new Lenovo and the hardware manual is not free availabe for download (very unusual).
https://support.lenovo.com/ch/de/solutio...
Peter Sidler - Ответить
Why would you edit and black-out the ASM, FRU and SN under the barcode of the battery sticker ?
Are you afraid someone is going to hack into your bank account or something with this info ?
There is nothing secret about these info that are written on the battery sticker.
These 3 codes are just there to identity the battery for process reasons and also in case it goes bad before warranty expires and you need to send the original battery back to the manufacturer.
Thanks for the guide.
gamer388 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 4
За последние 30 дней: 14
За всё время: 5,363
