Введение
Removing the back panel from the Toshiba AT1304T
If you can't get a hold of a Torx 6 Security Screwdriver, a small flathead can be used as a substitute
Выберете то, что вам нужно
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
If needed, use the flathead screwdriver to gently pry the panel from the phone.
Using your fingers, lift the panel from the device.
Еще один человек закончил это руководство.
