Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
This guide provides step by step instructions on how to disassemble the laptop in order to perform further repairs or replacements.
Выберете то, что вам нужно
Flip the laptop over so the bottom is facing up.
Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
Remove the twelve 8mm button head Phillips #00 B8 screws.
Remove the two 14 mm button head Phillips #00 B14 screws.
Remove the two 10 mm Phillips #00 battery compartment screws.
Remove the two 8 mm Phillips #00 screws.
Remove the seven 4mm flat Phillips #00 screws.
Remove the seven 20mm button head Phillips #00 screws.
