Введение
This is a step by step guide to show how to replace the keyboard. Prior to this guide, you will need to refer to the Disassembling guide for the case.
Выберете то, что вам нужно
Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
Remove the eight 6.0 mm JIS #0 case screws.
Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
Once the screw is removed, remove the blue plastic cover.
Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
Slowly remove the keyboard panel.
Remove all of the keys and set them aside with the keyboard panel.
Gently remove the keyboard circuit board with a plastic opening tool.
