Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Use a large plastic opening tool along the rear panel:
There are 4 clips to release.
Bend the second small plastic piece to release it from the rubber piece.
Now you can slide it out.
Remove the 4 rubber piece from the plastic frame at each corner.
Remove the rubber piece from the SATA/USB bridge logic board.
Remove both screws holding the retaining plate and the hard drive.
Slide the retaining plate in order to disconnect the SATA connector.
Remove both screws holding the retaining plate with the logic board.
