Отремонтируйте ваше устройство
Обучение ремонту
Магазин
Введение
This guide is a prerequisite for replacing other parts of an Xbox 360 E.
Запчасти
Детали не указаны.
  1. Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Continue sliding the spudger along the perimeter of the left grated face of the Xbox. Pull the top panel off. Pull the top panel off.
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
Заключение
3 участников успешно повторили данное руководство.
Jennifer
Участник с: 02.02.2014
1 648 Репутация
Автор 4 руководств
Команда
Cal Poly, Team 2-11, Amido Winter 2014 Участник Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 членов
Автор 25 руководств
Один комментарий
I broke my spudger! May I use anything besides that?
Colin2 Schrek - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 20
За всё время: 1,447
