Disassembling a Monroe LA-160 calculator
Выберете то, что вам нужно
  1. Disassembling a Monroe LA-160 calculator, Workspace: шаг 1, изображение 1 из 1
    • Prepare your workspace. Cover it with clean white paper or a white mat board. Light the area more than you think you'll need, and preferably from multiple directions.
    • Ready a cardboard box and lots of press-to-close bags to store the parts you pull off. Keep associated parts in their own bag, label each bag, and don't skimp on the number of bags!
    • Remove cats, small children, and capybaras from workspace. They like small parts, and you will be generating a lot of them.
  2. Disassembling a Monroe LA-160 calculator, Removing the carriage: шаг 2, изображение 1 из 3 Disassembling a Monroe LA-160 calculator, Removing the carriage: шаг 2, изображение 2 из 3 Disassembling a Monroe LA-160 calculator, Removing the carriage: шаг 2, изображение 3 из 3
    • Let's first remove the carriage, which is the top part with all the number wheels on them.
    • Position the calculator so that its keyboard faces you. This orientation defines the left and right sides of the calculator.
    • Insert a 1/8" flathead screwdriver into each of the indicated two screwheads on the right and left sides of the carriage, simultaneously.
    • Unscrew the left side screw.
  3. Disassembling a Monroe LA-160 calculator: шаг 3, изображение 1 из 3 Disassembling a Monroe LA-160 calculator: шаг 3, изображение 2 из 3 Disassembling a Monroe LA-160 calculator: шаг 3, изображение 3 из 3
    • Remove the left side screw.
    • Screw: 4-48 x 1/4", head 1/4" x 1/16"
    • Put it in a bag!
    • You should label each bag with the model number and serial number.
    • You can find the serial number by turning the calculator upside down and peering into the slot cut into the bottom, which gives you the model number and serial number.
    • Label the bag 1 so that you know where in the sequence this part was pulled off.
  4. Disassembling a Monroe LA-160 calculator: шаг 4, изображение 1 из 1
    • Put the bag in a box labeled with the model and serial number.
    • Pat yourself on the back. You are now officially organized.
  5. Disassembling a Monroe LA-160 calculator: шаг 5, изображение 1 из 3 Disassembling a Monroe LA-160 calculator: шаг 5, изображение 2 из 3 Disassembling a Monroe LA-160 calculator: шаг 5, изображение 3 из 3
    • Get something pointy, like a small screwdriver, and push it into the hole on the left side of the carriage that was revealed by the screw being removed.
    • This will push out the carriage shaft from the right side. Grab it and pull it out all the way.
    • Put the carriage shaft in your box of parts.
  6. Disassembling a Monroe LA-160 calculator: шаг 6, изображение 1 из 3 Disassembling a Monroe LA-160 calculator: шаг 6, изображение 2 из 3 Disassembling a Monroe LA-160 calculator: шаг 6, изображение 3 из 3
    • Pull back on the two carriage latches.
    • With the other hand, lift the carriage up and away.
    • On the underside of the carriage is inscribed the serial number of the machine, in case you couldn't read it from the slot in the underside.
    • Mine is serial number 241824. Also, apparently Stapler Guy was really possessive of this calculator.
  7. Disassembling a Monroe LA-160 calculator, Carriage Parts (top): шаг 7, изображение 1 из 3 Disassembling a Monroe LA-160 calculator, Carriage Parts (top): шаг 7, изображение 2 из 3 Disassembling a Monroe LA-160 calculator, Carriage Parts (top): шаг 7, изображение 3 из 3
    • Upper Dials. Consists of eight individual dials with black and red digits. Shows the multiplier in multiplication, and the result of division.
    • Lower Dials. Consists of sixteen individual dials, showing the result of addition and multiplication, the remainder in subtraction, and the dividend in division.
    • Dials Clear-out Crank. Rotate forwards one turn, stopping at bottom, to clear out upper dials. Backwards for lower dials.
  8. Disassembling a Monroe LA-160 calculator, Carriage Parts (bottom): шаг 8, изображение 1 из 3 Disassembling a Monroe LA-160 calculator, Carriage Parts (bottom): шаг 8, изображение 2 из 3 Disassembling a Monroe LA-160 calculator, Carriage Parts (bottom): шаг 8, изображение 3 из 3
    • Clutch mechanism. Drives either the lower shaft or upper shaft, but not both.
    • Lower Dials shaft and wheels.
    • Upper Dials shaft and wheels.
    • Zeroing shaft.
    • Carriage lifting shaft, only active when zeroing the Lower Dials.
  9. Disassembling a Monroe LA-160 calculator: шаг 9, изображение 1 из 1
    • Nelson White's U.S. patent "Zero-setting mechanism", filed in 1920, describes how this amazing thing works.
    • The clutch rotates one gear forwards when the crank is turned forwards, and it rotates another gear backwards when the crank is turned backwards.
    • One gear turns the upper shaft, the other gear turns the lower shaft. Little arms on the clutch lock the shafts into place when they are not turning.
    • On the left side of the carriage, cams on the upper and lower dials move a lever on the central zeroing shaft. Fingers on the zeroing shaft as a result move into place so that when the upper or lower shaft is rotated, the wheels stop when they display zero.
    • The zeroing mechanism rarely completely fails. It is useful to rotate the crank while observing all the different parts to gain an understanding of each part's function.
  10. Disassembling a Monroe LA-160 calculator, Removing the zeroing crank: шаг 10, изображение 1 из 3 Disassembling a Monroe LA-160 calculator, Removing the zeroing crank: шаг 10, изображение 2 из 3 Disassembling a Monroe LA-160 calculator, Removing the zeroing crank: шаг 10, изображение 3 из 3
    • Turn the carriage to the right side.
    • Holding on to the crank, remove this screw.
    • Put the crank and screw in bag #1.
  11. Disassembling a Monroe LA-160 calculator, Removing the lower dials: шаг 11, изображение 1 из 3 Disassembling a Monroe LA-160 calculator, Removing the lower dials: шаг 11, изображение 2 из 3 Disassembling a Monroe LA-160 calculator, Removing the lower dials: шаг 11, изображение 3 из 3
    • Remove this set screw.
    • Set screw: 5-44 x 1/8"
    • Put the set screw in bag #1.
  12. Disassembling a Monroe LA-160 calculator: шаг 12, изображение 1 из 2 Disassembling a Monroe LA-160 calculator: шаг 12, изображение 2 из 2
    • Turn the carriage to the left side.
    • Place the set screw in bag #1.
    • The set screws are used to align the shaft along its axis.
  13. Disassembling a Monroe LA-160 calculator: шаг 13, изображение 1 из 2 Disassembling a Monroe LA-160 calculator: шаг 13, изображение 2 из 2
    • This spring on the right side of the carriage needs to be removed.
    • Pull the arm on the right upwards to get better access to the spring.
  14. Disassembling a Monroe LA-160 calculator: шаг 14, изображение 1 из 2 Disassembling a Monroe LA-160 calculator: шаг 14, изображение 2 из 2
    • With the arm raised, use needlenose pliers to pull the spring off the arms.
    • Spring: Expansion, 0.31" compressed x 0.11", wire 0.014"
    • Place the spring in bag #1.
  15. Disassembling a Monroe LA-160 calculator: шаг 15, изображение 1 из 3 Disassembling a Monroe LA-160 calculator: шаг 15, изображение 2 из 3 Disassembling a Monroe LA-160 calculator: шаг 15, изображение 3 из 3
    • Spread the arms out.
    • Use a 3/8" wrench to hold the nut, and unscrew the bushing.
    • Remove the bushing, and put it in bag #1.
    • The nut stays in for now.
  16. Disassembling a Monroe LA-160 calculator: шаг 16, изображение 1 из 2 Disassembling a Monroe LA-160 calculator: шаг 16, изображение 2 из 2
    • Do the same on the left side of the shaft.
  17. Disassembling a Monroe LA-160 calculator: шаг 17, изображение 1 из 2 Disassembling a Monroe LA-160 calculator: шаг 17, изображение 2 из 2
    • A close-up of the bushing.
    • It is hollow and threaded on the outside, 1/4-32 x 1/8", and the head is threaded on the inside for the set screw.
    • Its head is 0.296" x 3/16"
  18. Disassembling a Monroe LA-160 calculator: шаг 18, изображение 1 из 2 Disassembling a Monroe LA-160 calculator: шаг 18, изображение 2 из 2
    • On the right side, lift up the Lower Dials shaft by the arm.
    • You can now get to the nut. Remove it and put it in bag #1.
  19. Disassembling a Monroe LA-160 calculator: шаг 19, изображение 1 из 2 Disassembling a Monroe LA-160 calculator: шаг 19, изображение 2 из 2
    • Still lifting on the right side of the shaft, turn the shaft so that the cam on the left side engages the pin.
    • Now lift up on the left side of the shaft to free it.
    • The left side nut may fall off, or not. If it tries to escape, make sure you see where it went.
  20. Disassembling a Monroe LA-160 calculator: шаг 20, изображение 1 из 3 Disassembling a Monroe LA-160 calculator: шаг 20, изображение 2 из 3 Disassembling a Monroe LA-160 calculator: шаг 20, изображение 3 из 3
    • Remove the nut from the left side of the shaft, or the floor, or wherever it ended up, and place it in bag #1.
    • Remove the Lower Dials shaft arm from the right side of the shaft, and place it in bag #1.
  21. Disassembling a Monroe LA-160 calculator, Removing the Lower Dials parts: шаг 21, изображение 1 из 2 Disassembling a Monroe LA-160 calculator, Removing the Lower Dials parts: шаг 21, изображение 2 из 2
    • The parts of the Lower Dials are fixed to the shaft using tapered pins.
    • During installation, the part is placed on the shaft, held in place, and then a hole is drilled through the part and the shaft using a taper pin drill bit.
    • Next, a taper pin is inserted into the hole until it stops, then it is pressed in with an arbor press. The pin is then cut or ground off.
    • Indicated is a hole in the Lower Dials driver gear for its taper pin.
    • In this dial spacer, the taper pin is clearly visible.
    • Rotating the shaft to the other side, we can see the over-enthusiastic application of a grinding head applied to the other end of the taper pin on the driver gear.
    • Meanwhile, the taper pin is again clearly visible on the dial spacer.
    • Removal of taper pins requires an arbor press and pin punches, and preferably a pin punch holder.
    • For this disassembly, you will need 1.1 mm or 1.0 mm pin punches, and you will need a lot of them, maybe ten or twenty, since they will often break.
    • Before you use a pin punch, cut it down to 1/4" or so using a Dremel or some other cut-off tool.
Заключение
Wowzers!
4 участников успешно повторили данное руководство.
robertcbaruch
Участник с: 08/18/11
515 Репутация
Автор 3 руководств
2 Комментариев
Thanks for posting this. My LA-200X is not zeroing out one wheel when on 1(black). This will help me tackle the repair.
Jason Stahl - Ответить
how to you remove the black knob on the right ? I am stuck here on mine
ftey2000 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 1
За последние 7 дней: 4
За последние 30 дней: 15
За всё время: 2,621
