Введение
Prerequisite guide to remove the main housing from iP21 for repair.
Выберете то, что вам нужно
Pry the four rubber feet from the bottom of the iP21 to expose four 11mm screws.
Unscrew the four 11mm screws from the base.
Pry the base loose using the spudger.
Remove the base by hand.
Remove the two black 6mm screws connecting the main circuit board to the housing top.
Gently pull front housing from the back housing.
Почти готово!
Заключение
