Введение
This guide has been updated by iFixit staff! Read the new, official guide here.
  1. Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Push the back glass towards the top of the phone.
    • Push the back glass towards the top of the phone.
  3. Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  4. Android Fix Kits
    A new screen or battery is one kit away.
    Купить сейчас
    Android Fix Kits
    Купить сейчас
  5. Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top  connector sheild. Using a plastic opener tool, pry up the battery connector.
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  6. Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
  7. Unscrew the 4 phillips screws holding the shield covering 6 of the 8 connectors.
    • Unscrew the 4 phillips screws holding the shield covering 6 of the 8 connectors.
    • Make sure to keep track of which screws are which, they very by tenths of a millimeter.
  8. Using a plastic opening tool, pry the back camera connector from the logic board. Be careful not to lose the small square peice of plastic covering the bottom of the camera, it comes off very easily.
    • Using a plastic opening tool, pry the back camera connector from the logic board.
    • Be careful not to lose the small square peice of plastic covering the bottom of the camera, it comes off very easily.
Заключение
4 участников успешно повторили данное руководство.
Chandler Skinner
Участник с: 15.10.2011
3 721 Репутация
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За 24 часа: 0
За 7 дней: 0
За 30 дней: 0
За всё время: 2,660
