Запчасти
No parts specified.
  1. Begin by removing the rubber grip along the handle.
    • Begin by removing the rubber grip along the handle.
    How do you take rubber piece off handle
    Billy Joe Furr - Ответить
    It appears the friction of your skin against the rubber grip can pull it down from the top enough that you can see how to peel it off.
    Matt Benson -
    How do you remove the rubber grip??
    octavia197424 - Ответить
    I have no rubber piece to remove
    Charlie changed her kelly - Ответить
  2. Remove the screws from the top to take the metal piece and plastic part off.
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. PC Laptop Batteries
    An easy fix for a big power boost.
    Купить сейчас
    PC Laptop Batteries
    Купить сейчас
  4. Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
    it doesn’t show any detail like the spring location
    kglenhunter - Ответить
  5. Here is the final result. This gives access to the switch button, chip set, battery and motor.
    • Here is the final result. This gives access to the switch button, chip set, battery and motor.
Заключение
12 участников успешно повторили данное руководство.
nathan
Участник с: 22.10.2013
1 171 Репутация
Автор 6 руководств
Команда
University of Maryland, Team 1-3, Shastany Fall 2013 Member of University of Maryland, Team 1-3, Shastany Fall 2013
UMD-SHASTANY-F13S1G3
3 членов
Автор 6 руководств
Комментариев: 3
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
Andrew Beeson - Ответить
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful.  Thank you so much
tundraorchid - Ответить
Thanks…worked well.
Magpie - Ответить
Добавить комментарий
Просмотр статистики:
За 24 часа: 10
За 7 дней: 83
За 30 дней: 335
За всё время: 25,938
