Disassembling the Canon PowerShot A200 Case
Выберете то, что вам нужно
  1. Disassembling the Canon PowerShot A200 Case, Disassembling the Canon PowerShot A200 Case: шаг 1, изображение 1 из 1
    • Use a Phillips #00 screwdriver to remove the two screws at the bottom of the camera.
  2. Disassembling the Canon PowerShot A200 Case: шаг 2, изображение 1 из 2 Disassembling the Canon PowerShot A200 Case: шаг 2, изображение 2 из 2
    • Locate a screw and a rubber covering on the left side of the camera. Slide the rubber covering to expose a second screw.
    • Remove both screws with the Phillips #00 screwdriver.
  3. Disassembling the Canon PowerShot A200 Case: шаг 3, изображение 1 из 2 Disassembling the Canon PowerShot A200 Case: шаг 3, изображение 2 из 2
    • Open the battery compartment on the right side of the camera by pushing slightly in the direction of the arrow.
    • Be sure to remove the memory card.
    • Remove the two screws by the memory card slot using the Phillips #00 screwdriver.
  4. Disassembling the Canon PowerShot A200 Case: шаг 4, изображение 1 из 2 Disassembling the Canon PowerShot A200 Case: шаг 4, изображение 2 из 2
    • Pull the grey tab towards the back of the camera. Lift the black cover to expose the battery slots.
    • Remove the two visible screws with the Phillips #00 screwdriver.
    • During reassembly, the holes for these screws must align properly with the interior of the camera body. Then the black battery cover must lie flat and be held in place by the grey tab.
  5. Disassembling the Canon PowerShot A200 Case: шаг 5, изображение 1 из 2 Disassembling the Canon PowerShot A200 Case: шаг 5, изображение 2 из 2
    • Remove the screen battery located to the left of the screen.
  6. Disassembling the Canon PowerShot A200 Case: шаг 6, изображение 1 из 2 Disassembling the Canon PowerShot A200 Case: шаг 6, изображение 2 из 2
    • Gently pull the camera apart from the top.
    • Be careful. The two halves are still attached by two short ribbons at the bottom of the camera.
  7. Disassembling the Canon PowerShot A200 Case: шаг 7, изображение 1 из 2 Disassembling the Canon PowerShot A200 Case: шаг 7, изображение 2 из 2
    • Locate the black tabs on either side of the white ribbon.
    • Use the metal tweezers to gently move these tabs to the outside edges of the ribbon.
    • Gently pull the white ribbon out from its connection.
  8. Disassembling the Canon PowerShot A200 Case: шаг 8, изображение 1 из 3 Disassembling the Canon PowerShot A200 Case: шаг 8, изображение 2 из 3 Disassembling the Canon PowerShot A200 Case: шаг 8, изображение 3 из 3
    • Locate the black tabs on either side of the orange ribbon.
    • Gently pull the orange ribbon out of its connection.
    • Your camera will now be in two separate pieces.
Заключение
Daniel Stone
Участник с: 01/28/11
101 Репутация
1 руководство автора
Команда
Cal Poly, Team 7-37, Regan Winter 2011 Участник Cal Poly, Team 7-37, Regan Winter 2011
CPSU-REGAN-W11S7G37
4 членов
Автор 10 руководств
0 Комментариев
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 1
За последние 30 дней: 3
За всё время: 655
