Введение
This guide will allow you how to access the internal components of the device.
Выберете то, что вам нужно
Flip the device to the backside, and locate the metal tab at the center of the back cover.
Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
7 участников успешно повторили данное руководство.
