Отремонтируйте ваше устройство
Обучение ремонту
Запчасти и инструменты
Введение
This short guide will give step by step instructions on the removal of the bottom panel of the Inspiron 7359 2-in-1. This disassembly requires the use of a Phillips #0 screwdriver, and a spudger.
  1. Turn off device  before starting.
    • Turn off device before starting.
    • Turn the laptop upside down with the logo facing the surface of the table.
  2. Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop. Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
    • Use a Phillips #0 screwdriver to remove the ten 8mm screws from the back case of the laptop.
  3. Manta Driver Kit
    112 bits for every fix.
    Upgrade Your Toolbox
    Manta Driver Kit
  4. Use a spudger to separate the back cover from the laptop.
    • Use a spudger to separate the back cover from the laptop.
    • Start from one corner and work your way around the edge of the cover.
    • Be careful not to bend or crack the back cover.
  5. All hardware components should be exposed.
    • All hardware components should be exposed.
Заключение
3 участников успешно повторили данное руководство.
meetkumar desai
Участник с: 08.10.2017
330 Репутация
Автор 2 руководств
Команда
Gateway, Team S1-G3, Saknee Fall 2019 Участник Gateway, Team S1-G3, Saknee Fall 2019
GCC-SAKNEE-F19S1G3
4 членов
Автор 6 руководств
Комментариев: 0
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 0
За последние 30 дней: 0
За всё время: 82
