Эта версия возможно содержит некорректные исправления. Переключить на последнюю проверенную версию.
Выберете то, что вам нужно
Этот шаг не переведен. Помогите перевести
Remove the other 6 screws.
Remove the hard disk and the RAM slots.
Ensure that the hard disk has been removed. Carefully detach the bottom cover.
Once the bottom cover is removed, your device should look like this.
Remove the 4 screws to detach the battery.
Remove all of the sticky tape.
Carefully disconnect the small power connector by using a tool to push the connector out through the small gap in the middle of the connector.
This is the Samsung 7.4V 45Wh battery.
Ensure that the battery is removed before continuing.
Remove the processor fan.
There are 2 screws holding it in place. Loosen and remove them.
Remove the processor heat sink.
3 screws hold this part in place. Loosen and remove them.
Disconnect the antenna cables from the WiFi card.
Remove the screw.
Remove the screw.
Lift the latch upwards to loosen the cable.
To remove the Motherboard, carefully disconnect the cables.
34 участников успешно повторили данное руководство.
30 Комментариев
Hello,
Do you know where can i reset the Bios CMOS in that motherboard?
I think there are people who wants to know becose system upgrade is leading to bios ACPI Error.
Thanks for your help
No, I do not know where is a reset pin of BIOS.
Try to disconnect NVRAM battery.
Wait 15 minutes and reconnect again.
