Disassembly of the Dreame L10s Ultra base station
Выберете то, что вам нужно
  1. Disassembly of the Dreame L10s Ultra base station, Remove the cover: шаг 1, изображение 1 из 2 Disassembly of the Dreame L10s Ultra base station, Remove the cover: шаг 1, изображение 2 из 2
    • Remove the four screws from the cover. Use a Phillips screwdriver to loosen them. Be careful not to lose the screws – they are small and can easily disappear!
    • Then fold in the hinges of the cover
  2. Disassembly of the Dreame L10s Ultra base station, Remove the top cover: шаг 2, изображение 1 из 3 Disassembly of the Dreame L10s Ultra base station, Remove the top cover: шаг 2, изображение 2 из 3 Disassembly of the Dreame L10s Ultra base station, Remove the top cover: шаг 2, изображение 3 из 3
    Инструмент, используемый на этом этапе:
    Jimmy
    $7.95
    • The top cover is held on with clips.
    • Carefully move the Jimmy underneath. Place the tool on an edge and slowly work your way around the casing to avoid damage.
    • You have to be especially careful around the area of the three buttons (see picture 3).
  3. Disassembly of the Dreame L10s Ultra base station, Remove the upper screws.: шаг 3, изображение 1 из 1
    • Take out the two marked screws using a PH2 screwdriver.
  4. Disassembly of the Dreame L10s Ultra base station, Remove the cover from the bottom: шаг 4, изображение 1 из 2 Disassembly of the Dreame L10s Ultra base station, Remove the cover from the bottom: шаг 4, изображение 2 из 2
    • Remove the seven screws on the bottom of the base station with a PH2 screwdriver
    • Detach the plate on the underside. To do this, take care of the clips in Fig. 2 above the label with the type designation.
  5. Disassembly of the Dreame L10s Ultra base station, Remove the screws at the bottom: шаг 5, изображение 1 из 1
    • Remove the two marked screws with a PH2 screwdriver.
  6. Disassembly of the Dreame L10s Ultra base station, Remove the screws at the back: шаг 6, изображение 1 из 1
    • Now you need to remove the cover for the seven marked screws. You can do this either with tweezers or, if you want to be sure that nothing gets damaged, with a Halberd Spudger.
    • Remove the seven marked screws with a PH2 screwdriver.
  7. Disassembly of the Dreame L10s Ultra base station, Remove the cover: шаг 7, изображение 1 из 1
    iFixit Opening Picks (Set of 6)
    • On both sides of the cover, the plastic hooks on my model are located at approximately the following positions, measured from the bottom:
    • 125 mm
    • 215 mm
    • 280 mm
    • 395 mm
    • 455 mm
    • The hooks are each about 10 mm wide and can be relatively easily removed with the help of the jimmy and prevented from snapping back in with opening picks.
    • The process is repeated on both sides.
  8. Disassembly of the Dreame L10s Ultra base station, Maintenance, repair, cleaning: шаг 8, изображение 1 из 1
    • Now the desired maintenance/repairs can be carried out.
    • In any case, it makes sense to at least remove the dust and dirt while the device is open. You can do this with compressed air or a brush so that you do not damage any sensitive parts.
Заключение
To reassemble your device, follow the steps in reverse order. When reassembling, be careful not to overtighten the screws, which could damage the case.
Еще один человек закончил это руководство.
Особая благодарность этим переводчикам:
de en
100%
Эти переводчики помогают нам починить мир! Хотите внести свой вклад?
Начните переводить ›
Sebastian
Участник с: 08/16/24
256 Репутация
1 руководство автора
1Комментарий к руководству
Has anybody found reliable sources for repair parts? The contacts for charging the robot have arc buildup. I tried contact cleaner and am planning on filing down, but would rather just replace.
Richard Malott - Ответить
Добавить комментарий
Статистика просмотров:
За последние 24 час(ов): 16
За последние 7 дней: 93
За последние 30 дней: 557
За всё время: 3,164
