Введение
This guide has been updated by iFixit staff! Read the new, official guide here.
Инструменты
Запчасти
Детали не указаны.
Loosen the two screws on the battery panel. Then lift the panel up to remove it.
L Button.
Top of the battery pack.
To remove the battery pack, place your fingernail or a spudger at the top of the battery near the L button. Gently lift the battery out.
Two screws are hidden underneath two rubber feet highlighted in red.
Use the tip of a spudger to pry the rubber feet out of the lower case.
Remove the following screws securing the lower case to the body of the DSi:
Six 5.2 mm Phillips #00 screws.
One 2.7 mm Phillips #00 screw.
Insert the spudger in between the lower casing and lower panel near the top right corner of the DSi.
Carefully run the spudger along the edge of the outer casing, creating an opening between the body and the casing.
Continue running the spudger around the body of the DSi until the majority of the lower case has been separated.
Carefully lift the lower casing from its bottom edge.
Pry the volume and SD board cable up from its socket on the motherboard using a spudger.
Once the cable is completely removed, then you may take off the entire outer casing.
Flip up the black latch and disconnect the D-Pad/Power Button ribbon cable.
The connector is two pieces -- a white "male" piece (connected to the wires), and a beige "female" part (soldered to the main board).
There is a small "notch" in the female part, to give you a place to insert a small flat-head screwdriver. Put the corner of your screwdriver in there, and twist it gently to push the white part up (away from the main board). Do not try to pull it to the right (towards the battery board).
Еще один человек закончил это руководство.
