Введение
Prerequisite-only instructions for disconnecting the battery in the Samsung Galaxy S8+.
Выберете то, что вам нужно
Remove the eleven 3.7 mm Phillips screws securing the wireless charging coil + antenna assembly.
If any screws are difficult to remove even when fully loosened, you can pull them out with tweezers.
Use a spudger to gently pry up the plastic in the marked areas to pop the clips free.
Use a spudger to disconnect the battery by prying the connector straight up from its socket.
