Этот документ имеет более свежие изменения. Перейти к последней непроверенной версии.
Введение
Installing a new charging port may be necessary if you are having trouble charging your battery. Installation should only be done as a last resort, after trying other possible solutions as listed in the Nokia 8290 Troubleshooting Guide. Installation requires no prior knowledge of mobile phone charging ports.
Выберете то, что вам нужно
Locate the small button on the top of the phone.
Depress the button.
With your other hand, pull the front cover away from the phone.
Remove all six 5.3 mm long T6 screws.
Remove the circuit board/faceplate sub-assembly from the back of the phone.
There is another part located directly underneath the part removed in the previous step. Use tweezers to remove this part as well.
After removing the two parts, locate the charging port.
Use tweezers to remove the charging port.
