Введение
If one of the tail lights in your 2004 Dodge Durango is not lighting up, you may need to replace the bulb inside. A faulty bulb may result in a costly fine or an accident on the road, as tail lights are essential for signaling other vehicles. Before trying this guide, first check if the car’s battery is fully charged and functional.
Make sure the car’s engine is off, the parking brake is engaged, and the battery is disconnected before beginning this guide.
Выберете то, что вам нужно
Locate the connector and pull the orange safety pin out.
After the safety pin is out, pull on the connector plug to separate it from the tail light.
