Dodge Ram 1500 Headlight Bulb Replacement
Выберете то, что вам нужно
    1. Dodge Ram 1500 Headlight Bulb Replacement, Headlight Assembly: шаг 1, изображение 1 из 3 Dodge Ram 1500 Headlight Bulb Replacement, Headlight Assembly: шаг 1, изображение 2 из 3 Dodge Ram 1500 Headlight Bulb Replacement, Headlight Assembly: шаг 1, изображение 3 из 3
      • Open the hood by pulling the hood lever in the driver-side footwell.
      • Reach under the center of the grille and press the hood latch.
      Спросите у FixBot
      Добавить комментарий
    2. Dodge Ram 1500 Headlight Bulb Replacement: шаг 2, изображение 1 из 1
      • In this guide we will be removing the left headlight. The steps are mirrored for the right headlight.
      Спросите у FixBot
    3. Dodge Ram 1500 Headlight Bulb Replacement: шаг 3, изображение 1 из 3 Dodge Ram 1500 Headlight Bulb Replacement: шаг 3, изображение 2 из 3 Dodge Ram 1500 Headlight Bulb Replacement: шаг 3, изображение 3 из 3
      • Use the 10 mm socket wrench to unscrew the first of three 12 mm long 10 mm hex-head screws holding in the headlight assembly. The screw is located just to the left of the headlight assembly.
      • Unscrew the second screw located approximately 6 inches below the first.
      • Locate the third screw at the bottom left corner of the headlight assembly just behind the bumper and remove.
      • When re-installing the screws do not over tighten. Over tightening the screws will result in stripped threads.
      Спросите у FixBot
    4. Dodge Ram 1500 Headlight Bulb Replacement: шаг 4, изображение 1 из 2 Dodge Ram 1500 Headlight Bulb Replacement: шаг 4, изображение 2 из 2
      • Approach this step with the process of unbuttoning a shirt in mind.
      • Be careful if the rubber gasket is dry-rotted. Use vaseline to re-moisturize if necessary. Manipulating dry-rotted rubber will result in tearing.
      • Pinch the bottom of the rubber gasket at the left side of the assembly and remove it from the plastic "buttons" on the headlight assembly.
      Спросите у FixBot
    5. Dodge Ram 1500 Headlight Bulb Replacement: шаг 5, изображение 1 из 2 Dodge Ram 1500 Headlight Bulb Replacement: шаг 5, изображение 2 из 2
      • Locate the blue headlight wire. Use a flathead screwdriver to pry up one side of the clamping teeth and pull the connector off.
      • Locate the green turn signal wire clamp. Use a flathead screwdriver to push in the tab on the side and pull off the connector.
      • Now that all connections between the car and the headlight assembly are disconnected, it is safe to remove the headlight assembly from the truck.
      Спросите у FixBot
    1. Dodge Ram 1500 Headlight Bulb Replacement, Headlight Bulb: шаг 6, изображение 1 из 2 Dodge Ram 1500 Headlight Bulb Replacement, Headlight Bulb: шаг 6, изображение 2 из 2
      • Rotate the outer ring of the headlight bulb holder counterclockwise to remove it.
      • Carefully pull the headlight bulb holder out of its socket.
      • When installing a headlight bulb, do not touch the bulb with your bare skin. Wear gloves when installing a new headlight bulb. Halogen bulbs are sensitive to skin oils, and the bulb may burn out quickly if you touch the bulb during installation.
      • If you accidentally touch the bulb, clean it immediately using rubbing alcohol on a clean cloth.
      Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
Michael Saggese
Участник с: 10/05/12
1 228 Репутация
Автор 6 руководств
Команда
Cal Poly, Team 3-24, Amido Fall 2012 Участник Cal Poly, Team 3-24, Amido Fall 2012
CPSU-AMIDO-F12S3G24
4 членов
Автор 37 руководств
1 Комментарий к руководству
What is that rubber gasket called or a part # please, mine is all torn from previous owner
diggemsmacks2000 - Ответить Поделиться
Статистика просмотров:
За последние 24 часов: 1
За последние 7 дней: 20
За последние 30 дней: 85
За всё время: 30,924
