Dopo Double Power 7 Battery Replacement
Выберете то, что вам нужно
  1. Dopo Double Power 7 Battery Replacement, Rear Panel: шаг 1, изображение 1 из 1
    • The rear panel is secured to the front case and can simply be pried apart without damage.
    Спросите у FixBot
    Добавить комментарий
  2. Dopo Double Power 7 Battery Replacement: шаг 2, изображение 1 из 1
    • Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
    Спросите у FixBot
  3. Dopo Double Power 7 Battery Replacement: шаг 3, изображение 1 из 1
    • Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
    Спросите у FixBot
  4. Dopo Double Power 7 Battery Replacement: шаг 4, изображение 1 из 1
    • The rear panel should come completely off.
    Спросите у FixBot
  5. Dopo Double Power 7 Battery Replacement, Battery: шаг 5, изображение 1 из 1
    • Cut only the red and black wires attaching the battery to the motherboard.
    • Be sure to remove any remaining wire attached to the motherboard.
    Спросите у FixBot
  6. Dopo Double Power 7 Battery Replacement: шаг 6, изображение 1 из 1
    • Using a metal spudger, carefully pry the battery away from the digitizer.
    • Be careful to not damage the battery. This could result in injury.
    Спросите у FixBot
  7. Dopo Double Power 7 Battery Replacement: шаг 7, изображение 1 из 1
    • Using wire strippers, strip the ends of the red and black wires connected to the the new battery back about a 1/8".
    • Twist the strands of the spliced wire together.
    • Using a soldering iron, apply heat to one bare wire connections you have just made.
    • When the connection is hot enough melt solder on the opposite side of the wire to the iron as shown in the image. Do not melt to much solder.
    • Once connection is made wait for it to cool off and gently pull each side of the wire to test durability.
    • Repeat this process with the other wire.
    • If you do not have access to a soldering iron, leave the old battery wires attached to the motherboard and simply splice the new battery's wires to them.
    • This video provides basic instructions for splicing wires using crimping and heat shrink technique.
    Спросите у FixBot
Заключение
Еще один человек закончил это руководство.
mike pelosi
Участник с: 10/30/15
682 Репутация
Автор 6 руководств
Команда
UMass Dartmouth, Team 1-2, Miles Fall 2015 Участник UMass Dartmouth, Team 1-2, Miles Fall 2015
UMASSD-MILES-F15S1G2
4 членов
Автор 12 руководств
0 Комментарии к руководству
Статистика просмотров:
За последние 24 часов: 3
За последние 7 дней: 13
За последние 30 дней: 43
За всё время: 1,298
