Введение
Use this guide to replace the motherboard in your Dopo Double Power 7.
Having a functioning motherboard is crucial because it is the component that holds all of the hardware that allows your device to work such as storage devices, the processor, and the power supply.
If you are experiencing problems such as no power, random errors, or crashes you may need to replace the motherboard of your Dopo Double Power.
A skill you may need for this repair is soldering.
Выберете то, что вам нужно
The rear panel is secured to the front case and can simply be pried apart without damage.
Carefully, wedge the plastic opening tool in-between the seam that separates both halves of the tablet.
Run the plastic opening tool along the seam looking for the clips and lift up on the rear panel.
Using the flat end of a spudger or tweezers, remove the three cables connected to the motherboard.
The cables can be disconnected by lifting up on the black section of the socket, as shown by the arrow.
Using a Phillips Head Screwdriver size 0, remove the four screws attaching the motherboard.
Using wire cutters, cut the red, black, and grays wires.
The motherboard can now be removed
Еще один человек закончил это руководство.
