Введение
Having issues with your motherboard? This guide will provide instructions on how to remove the existing motherboard on your device.
Выберете то, что вам нужно
Wedge a plastic spudger between the back panel and the screen to begin lifting the back cover.
Wedge around all edges until the back cover pops off entirely.
Remove tape covering wire joints
Remove (3) 2.5mm screws using a PH001 screw driver.
The screws locations are highlighted in the image to the left.
Remove black tape and using your fingers, pull the orange ribbon labeled BSR028-V3-KDX out of its port.
Remove the last orange ribbon labeled 24 by pulling the motherboard away from the ribbon
Desolder the wires attached to the mother board with a soldering iron.
Then pull the wires from the joints.
