Введение
This is a prerequisite guide only. In the following steps, you will remove two exterior parts, then remove the screws that hold the casing together.
Инструменты
Запчасти
Детали не указаны.
Start by removing the housing cap by unscrewing it.
Next, unscrew the now exposed collet nut while holding down the shaft lock button.
Using the Torx 15 screwdriver tip, remove the 5 screws (12.5 mm) that hold the casing together.
Use your hands to carefully remove the back casing so that none of the components fall out.
2 участников успешно повторили данное руководство.
