Введение
If the motor burns up or the power switch breaks, you are going to need a whole new motor and shaft for the device, as they come as one piece. This guide will show how to dissemble and remove the motor-shaft assembly.
Выберете то, что вам нужно
Pull back on the release tabs to disconnect the battery pack from the housing.
Remove the two screws from the back of the device with the TR10 Torx Security screwdriver.
Lift off the unscrewed plastic cover at an angle, away from the tip of the device.
3 участников успешно повторили данное руководство.
