Dremel 8220 Gear Lock Button Replacement
Выберете то, что вам нужно
  1. Dremel 8220 Gear Lock Button Replacement, Gear Lock Button: шаг 1, изображение 1 из 1
    • Locate the battery at the back of your Dremel. Firmly grasp the battery on both sides and pull. It should easily come out of the battery well.
  2. Dremel 8220 Gear Lock Button Replacement: шаг 2, изображение 1 из 1
    • Remove the ring located around the speed selector switch by pulling apart on either side. This should require very minimal force.
  3. Dremel 8220 Gear Lock Button Replacement: шаг 3, изображение 1 из 1
    • Remove the collar wrench by pushing the gear lock button. Continue to hold this button as you rotate the wrench counter-clockwise until it is removed.
  4. Dremel 8220 Gear Lock Button Replacement: шаг 4, изображение 1 из 1
    • Remove the metal clasp from the battery well. This piece helps hold the plastic shell of the device together. Pry it out by gently applying some force with a screwdriver.
  5. Dremel 8220 Gear Lock Button Replacement: шаг 5, изображение 1 из 3 Dremel 8220 Gear Lock Button Replacement: шаг 5, изображение 2 из 3 Dremel 8220 Gear Lock Button Replacement: шаг 5, изображение 3 из 3
    • Remove the 5 torx screws using a t9 screwdriver head.
    • Now pull apart the plastic shell of the device. If you are not able to, review the previous steps as you may have missed one.
  6. Dremel 8220 Gear Lock Button Replacement: шаг 6, изображение 1 из 1
    • Remove the faulty gear lock button. It should come out of the device easily with no force needed.
Заключение
connor anisko
Участник с: 03/09/16
306 Репутация
Автор 2 руководств
Команда
UMass Dartmouth, Team 2-8, Isaacson Spring 2016 Участник UMass Dartmouth, Team 2-8, Isaacson Spring 2016
UMASSD-ISAACSON-S16S2G8
3 членов
Автор 5 руководств
3 Комментариев
I’m assuming the issue I have is a faulty gear-lock button (that, or the locking gear that it restricts when depressed). If so, did you find a replacement button from the manufacturer? In my experience, they rarely offer repair parts themselves.
Robert - Ответить
I also don’t understand why there was a flag claiming that this should be broken into separate guides. People aren’t THAT stupid, I hope.
Robert - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 0
За последние 7 дней: 7
За последние 30 дней: 18
За всё время: 733
