Dremel MultiPro 395 Carbon Brushes Replacement
Выберете то, что вам нужно
  1. Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Blue Caps: шаг 1, изображение 1 из 2 Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Blue Caps: шаг 1, изображение 2 из 2
    Инструмент, используемый на этом этапе:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Купить
    • Remove the blue caps located on either side of the MultiPro using a 3 mm flathead screwdriver.
  2. Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Carbon Brushes: шаг 2, изображение 1 из 2 Dremel MultiPro 395 Carbon Brushes Replacement, Remove the Carbon Brushes: шаг 2, изображение 2 из 2
    • Carefully remove the carbon brushes attached at the end of the springs by gently pulling on the springs using your hands.
  3. Dremel MultiPro 395 Carbon Brushes Replacement, Insert New Carbon Brushes: шаг 3, изображение 1 из 2 Dremel MultiPro 395 Carbon Brushes Replacement, Insert New Carbon Brushes: шаг 3, изображение 2 из 2
    • Carefully insert the new carbon brushes into the location of the old carbon brushes using your hands.
Заключение
6 участников успешно повторили данное руководство.
Matthew Satton
Участник с: 09/17/14
520 Репутация
Автор 2 руководств
Команда
University of Kentucky Louisville, Team 1-5, Mathis Fall 2014 Участник University of Kentucky Louisville, Team 1-5, Mathis Fall 2014
LOUISVILLE-MATHIS-F14S1G5
5 членов
Автор 4 руководств
3 Комментариев
Yeah. And if you've overheated your Dremel to the point where it quits running, the brushes may be melted in place. Disassemble the two halves of the case, and push against the brushes from the inside, using the armature. After they pop free, you'll probably find that your switch has melted as well. Return the whole thing to Dremel, and if they can't fix it cheaply, they'll give you a good deal on an upgrade to a newer model. Cheers!
Tor Matson - Ответить
How strongly are the brush springs attached to the carbon brushes? My brushes do not look very worn, they measure .2445" (carbon block only). However, one side the spring and the brush make contact but are not held together by anything other than the spring tension. Is this a problem?
mycle85719 - Ответить
I still have approx 1.5 cans on the brushes but it has stopped working, do they need changing?
jamessteele2 - Ответить
Добавить комментарий
Просмотр статистики:
За последние 24часов: 2
За последние 7 дней: 13
За последние 30 дней: 70
За всё время: 13,448
