Введение
If your playback sounds scratchy and not up to par, try replacing the speaker of your device with this guide.
Выберете то, что вам нужно
Push the black battery tab next to the battery to get the battery out.
Remove the battery.
Remove six 8mm long Philips head screws with the J0 Philips head from the outer case.
Remove the wires connecting the speaker to the motherboard from the motherboard, and solder the wires connecting the new speaker to the motherboard in the same locations as the wires that were removed.
