Введение
The internal fan keeps your machine from overheating. A faulty fan can also cause smoking. To remedy these problems, use this guide to replace your fan.
Выберете то, что вам нужно
Remove the seven 14mm screws from the side of the drill using the PH#0 screwdriver.
Remove the top casing to reveal inside of drill. You might have to tug a little harder for this one.
Почти готово!
Заключение
