Введение
This guide show how to replace the screen of the Motorola Droid MAXX 2 smartphone.
Выберете то, что вам нужно
Insert a small pointed object into the hole on the sim card tray to eject the tray from the phone.
Wedge your thumb into the indent located on the bottom left corner of the back cover and pull up to remove the back cover.
Remove the static tape covering the two connectors.
Use a spudger to disconnect the battery cables from the motherboard.
If battery has adhesive, use heat gun for one to two minutes to loosen it. Be careful of the points outlined in red when prying it up. Use guitar picks or a spudger to gently lift the battery and separate the adhesive.
We will be removing these 3 ribbon cables.
Using an opening pick, lift the grey tab on the rear camera's ZIF connector. Remove the ribbon cable and the camera.
Use tweezers to lift up on the grey latch on the ZIF connector.
Remove the ribbon cable from the ZIF connector.
Use a pair of tweezers to lift up the black latch on the ZIF connector.
Pull the ribbon cable out of the ZIF connector.
Using a metal spudger, work your way around the perimeter of the main board and screen.
2 участников успешно повторили данное руководство.
